I just read an article on hp vs. tq posted by Steve Toner. http://www.g-speed.com/pbh/torque-and-hp.html
"It is better to make torque at high rpm than at low rpm, because you can take advantage of *gearing*."
I am having difficulty wrapping my head around this statement. Doesn't high torque at low rpm determine that feeling of acceleration (flat torque curve) until redline? HP helps top speed but torque is what accelerates the vehicle, correct?
So, if the above statement is correct, what is an example of proper (clever) gearing to take advantage of 7,500 rpm 331 or 306 producing 500 hp and 350 lbs torque, for example, or any high rpm motor?
Use shorter gearing? 35 mph first gear or use a Getrag or similar ratios? Yuck /ubbthreads/images/graemlins/tongue.gif
Would this be similar to using a stroked 408 with 500hp/500tq that uses taller gearing?
Then again, I have heard that high tq motors like a stroker make the car somewhat undriveable because of the rear end stepping out under acceleration in the corners.
It is all a bit confusing /ubbthreads/images/graemlins/confused.gif.
