Bobs GTD
Ha All,
I just had to post a few pics of my new acquisition its a 347 stroker with a ford motorsports block I got this as it sits with everything on it and all the paperwork to go with it. Got an excellent deal on it.
See ya,
Bob
Looks good Bob...Do you mind if I stop by sometime and check it out?
I'm also from the Richfield area.....Hillside & monches rd...
Ha All,
I got the machining done on the flywheel today, it just needs to be balanced and its finished.
See Ya ,
Bob
Hi All,
Well the last couple of weekends I have been busy working on the car, so here is what I have done.
1) I had to make Alum. inner fender covers for the headlights, because they stuck out of the enclosed area they fit in,the pictures explain better than I can, so I welded up some boxes to cover them up.
2) The louvered panels I got with the car were polished (somewhat) stainless steel, but I personally like the brushed stainless look better, so there they are all brushed and ready.
3) I made a stainless steel turn signal arm with my high/low beam headlight button built in the end, should be very convenient to get to, no fumbling around with trying to find a foot switch or a dash mounted switch.
4) And finally after a year of engineering and back and forth with drawings and dimensions, I got my single piece input shaft and new first and second gears for my UN1 box, I can't wait to get it put together , and by the way does anyone see anything different about my 1 piece shaft? Notice that the first gear on the input shaft is NOT a straight cut gear! And they said it couldn't be done, Wrong here it is.
I look forward to any and all feedback.
Thanks,
Bob
I guess it didn't like all my pics at once so here are the rest
Happy Holidays To All,
Well I did get a chance to do a little work on the 40 over the holiday, I put in the fittings for my trans cooler, mounted my louvers and check out the cool LED license plate lights and the interior lights, these things only draw 30 milla-amps each. Well its snowing like crazy here so I have to go plow.
See ya Later,
Bob
HI Bob What switch did you use? Is this detented to lock on high beam? Are you going to make these one piece shafts available ?????? Thanks
I took a few pics of the LED lights in the dark to see how they look
This weekend I made a new bulkhead flange for the steering column the old one was a piece of crap, its amazing what you can do with a few pieces of steel and a hammer. next was the sound deadening material I got that all put in and then the door rubber boots you see in the last pic will be mounted this week.
See ya ,
Bob
Ha All,
Well I did manage to get in the rubber boots to the doors as you can see by the pics and I also made new door stops, I was not a real fan of the limit strap look as seen on a lot of cars, my father in laws model A ford has those and I think its ugly so I redesigned my own. They seem to work just fine but time will tell ! Well back to work.
See Ya,
Bob
Ha All,
Well just a quick one this time I was able to get the lower panels on and then finish the door sill seals this week.
Se Ya,
Bob
Bob
this door stops will put a lot of stress on the fiberglass where it is connected to the hinges, due to the leverage ratios you have.
TOM
