For Sale GT 40 MK 1 replica by Bailey Cars South Africa built in 2005 to Race Quality spec.’s Dark Blue exterior
A race winning street gas Bailey GT 40. This was Peter Bailey’s actual car,
which has won races in South Africa and in the USA i.e. the HSR Mitty2014.
The current owner of this car is so impressed with the drivability of this Bailey machine that he has ordered a new “full race Bailey GT 40”.
Which allows someone to acquire this half street, half race beast at a great price. This car is powered by a Keith Craft 302 pumping 474 BHP HP. at 7,400 RPM (build sheet and dyno graph upon request)
How? By going old school with a solid cam.
This cam gives you the edge accelerating out of corners while still running on pump fuel for those who want to terrorize the street.
The horse power is connected to the street via a Porsche 944 turbo trans with Audi gears new fuel pumps ,
Chassis: Laser cut carbon steel space frame chassis (which has a torsional stiffness of 18500Nm/design)• Laser cut aluminum panels which are then bonded and riveted to the chassis
The rear suspension is an independent double trailing arm with transverse top link and lower wishbone.• Shock absorbing comes from coil over type with H&R springs. Aurora rod ends fitted as standard• 2.4 turns lock to lock steering ratio Fully custom built Bailey uprights made of top quality 7075 Aircraft Aluminum
Race interior, this has Increased cockpit space for driver comfort and safety with a full race roll cage and a passenger seat
Powertrain : Keith Craft 302 475 HP Iron block, aluminum heads, solid lifter cam, quick fuel 4 barrel carb runs on street petrol
Eldelbrock PERF air intake port matched intake manifold.
Gear train: Porsche 944 Turbo limited Slip Transaxle fitted with Audi gears, with new CV joints
Halibrand wheels with 8 inch wide front and 10 inch wide rears New Race Tires.
Brakes: A/P 4 pod racing calipers with new pads.
Full 5 point harness and full fire suppression system 13-inch, 3 spoke steering wheel• Rake and height adjustable steering column• Sliding floor mounted BEC pedals Sliding passenger foot rest cockpit space for tall drivers up to 6 foot 5 inches tall
90 litre fuel tank capacity• Rubber bladder type fuel tanks• Exhaust mufflers and straight pipes with new megaphones
Oil cooler with braided lines and Aeroquip fitting Aluminum radiator with dual electric fans.
This Car has raced once with the new engine and won the HSR Mitty 2014 Georgia USA
It is fully sorted and ready to run and win.
Bailey Cars North America Stands behind this monster...100%
[email protected]
$86,000.00 USD for this screamer
[email protected]
