Dave Hood
I've had my Eight Stack system for about a year now and it's very good. I like the vintage look of the system, and the company is great to work with. www.eightstack.com
What is the throttlebody diameter on this 302 setup or are they available in different sizes ?
What ECU is recommanded ?
TOM
.....We also do the TWM version, www.twminduction.com they come in 48mm and 50mm. For a 351W they can do a version with the 58mm Big Block throttle bodies.
We do the Accel DFI system the same as Roush uses but we have developed our own kit.
Mike,
How is the linkage arrangement between the two setups? Which one has the least amount of bellcranks and linkages? The way I see it, these are all potential wear points which can throw off the synchronization between throttle bodies and add more slop to the system. Also, heat can be a factor on all these moving parts. I see the TWM has the zero backlash type flex coupling between throttle bodies, so that's a plus.
I like the more period correct look of the 8 Stack system, and I like what I can see with the TWM's mechanical arrangement which could equate to a more stable setup in the long run.
Are you in a position where you can speak your opinion on both systems?
Thanks,
Tom
Borla Induction 302 and 351 eight stack systems now ship with fuel rails configured for EV6 and EV14 Bosch injectors.
Garry Polled
