1990 Ford gt GTD Developments
if anyone has a Ford gt built by GT Developments in Poole around 1990
I would like to chat with as I am trying to find out what the switches and pull switch is located under the dash
Probably quite a few in here... Try to search for GTD
This is a kit car, so the parts you have under your dash might not be part of the standard equipment. Might have been added during the initial build or by someone at a later stage. The triangle knob is probably warning lights. You just have to investigate on the rest...
Mike Pass
Hi Len,
I have a GTD very similar to yours but my car does not have those parts. They will have been fitted by the builder or later owners. I do have some GTD information. If you would like copies drop me a PM via this forum with your email address and I will send them to you.
The pull cable could be for a manual choke, or an air flow diverter door, or possibly even a fire suppression system, although fire suppression knobs tend to be red and have a safety pin to avoid an accidental discharge.
Also thinking maybe it’s a pull for a heater core, removed from my MDA during removal of EPAS as a need for adding more warm air into the cabin had never occurred to me.
as others have said, not standard fitting locations for these switches / cables.
the pull switch with the triangle emblem, should be hazard lights.
the push/pull cable was usually connected to the open/close valve controlling the hot water flow to the heater matrix under the dashboard.
Lee4tgt is right. I have same and my gtd was build by gtd themselves in 1991. Quiet sure you have air conditioning.
