DAX Build Up
Well I hink it is about time to start up a thread about the DAX.
I bought it about a year ago and posted some pictures in this thread.
http://www.gt40s.com/ubbthreads/showflat...=true#Post48628
It became apparant very quickly that I was going to battle with space as the garage is about 7'6" wide and the car 6".
Anyway over the summer I pushed it out the garage onto the hardstanding and started doing some work - each time I did the weather turned and it rained. So pack it all up and push it back in!
I looked at extending the garage, installing a new one at the rear of our garden but "She who must be obeyed" said no to me taking over
I had also taken this time to purchase other bits and pieces missing from the purchase, Radiator, Fans, some lights, exhaust etc.
By October I was starting to get so miffed by the lack of progress that I considered throwing in the towell.
It was around that time that Paul Walton came to one of the Enthusiast Club meetings and I suggested tongue in cheek, that he build my car after his got SVA. He did not turn me down flat and after various discussions we agreed to move the car into his garage and get it on the road. This will be a no frills car - no air con - no internal lights - no radio ----- yes the Keep it simple worked for me!
The first thing that happened was Paul had booked his SVA test but had no tyres as there had been a hiccough on them. I said take mine to get through the test and he duly arrived with a set of "Granada" wheels to swap for mine.
Should be easy - jack up, unbolt remove and fit the other set.
Reality was Jack up remove the rears offer up the Granada ones and "Oh Sh%t" the granada offset means the nner tyre wall rubs on radious arm.
Bugger it all we needed was something to allow us to roll my car back into the garage when Paul's was at SVA.
Decided if we spin the car - swap the front wheels (they worked and fitted)
sttach a chariot wheel in timber - Roll it into the garage, remove the last rear wheel and place on axle stands.
We thought that this may be able to rake right hand bends but on lefthanders may battle for grip!
Got to Paul's As usual it rained when this car came out the garage
Pictures for SVA re Seat belt mounts (If any one is reading the SVA will want to confirm how the Belt brackets are mounted - photo evidence is acceptable)
Up side pod from rear to "fitted fuel tank" Spot the mistake - It was a car ordered with EFi and there are no returns. First job is to remove them and get returns fitted.
Also had to remove the fuel filler caps as they stand proud of the body and will Fail SVA
These jobs took the best part of a day!
The Dax radius arm? in the above photo can be seen as one of the big differences to oher 40's as they go almost straight forward and inside the side pod. (Tornado and GTD go inboard close to the engine.
The dust is from 15 years of build so far (previous builder 14 years and in my posession 1 year,
Seriously considering at this stage that I will link both tanks together in the engine bay (Say 1/2 inch across the bay) draw from 1 tank and return to the other - a damn slight easier than returning to the tank being drawn from.
Might be worth mentioning at this point we have 16 weeks to finish the build so you can drive to the Classic Le Mans. (This allows 2 months for SVA and registration) Better get out there and do a bit then. /ubbthreads/images/graemlins/zzzzz.gif
Geeze - I must calm down on the booze a bit, double vision.......
DAXNADO Paul's Tornado nostril on the Dax Amazing difference in thickness - the Dax is definately not a lightweight!
Front brakes AP units that bolt direct to Granada hubs
(I was advised off a Porsche 944)
Has any body used this caliper on a 40 and are they up to the job?
Paul has been working wonders this week
First got one drive shaft in - these are from VW transporter Mk2 no mods needed just clean up the CV and bolt in. One CV wa knackered so I have now hunted down the correct part.
Front lights, indicators (to be removed for SVA) and driving lights fitted
Bracket for the Fluid Resevoirs (Brake and washer) and brake pedal masters fitted (Double thickness windscreen as Paul's is on top when his car is at the painters. Also visible is the windscreen wiper mechanism not installed
