Since getting the floor completed a couple of months ago, I have been busy collecting parts and making tweaks to the chassis to accommodate accordingly.
All the body work has been given a through clean with warm soapy water and 1500 wet & dry to get rid of the many years of grime and given a polish - amazed and please by how it came out.
The front sub frame has been modified and strengthened to take coil overs, the original spring support arms were removed, the top mounting point for the coil overs has had additional metal welded in and the rest of the area have been seam welded, with all the front suspension parts blasted and painted and new polly bushes/ball joints etc.
With the sub frame fitted and the steering rack in place, attention then turned to fitting a steering column, power steering was an absolute, so a Corsa unit was the obvious chose and went for the adjustable version. Three brackets have been fabricated with the main central one welded into the frame work with vertical and lateral bracing, the forward and aft brackets then bolt into the central bracket and lateral bracing.
Having decided to stick with the original roll hoop rather than a full cage, I made a pair of support braces to tie into the rear of the chassis.
I have squared off the chassis frame in front of the windscreen in preparation for mounting fuel fillers, although visually it looks completely level from one side to the other it does raise up slightly at the outer ends, so took a while to get the fit correct so that the mounting surface for the fuel fillers is completely level.
Picked up a 302 engine this weekend from an early 80’s Lincoln Town car, will be fully stripped and re-built – but for £200 a perfect starting point.
Tony
Tony
