Coyote 8 Stack EFI Kit
Andy Sheldon
Tornado Sports Cars
GT40s Sponsor
A new 8 stack EFI fuel system for use on the Coyote V8 engine. Supplied complete including inlet manifolds, throttle bodies, fuel rails, linkage, ECU, wiring and all sensors etc.
A complete fuel system kit is also available including all fuel pumps, filters, regulator, swirl pot, electro magnetic return valves and braided hoses with aircraft fuel fittings.
The single ECU operates the Coyote V8 engines quad cam system and using the standard Coyote fuel injectors and ignition coil packs.
