Not a lot has happend since last post...
but
Father Christmas has made an early stop...
I have now decided to go with a dry sump system and taken delivery of an AVIAID geared pump and crank fittings for belt drive.
This means of course that have to take sump off, add some scavange connections ( -12) to the side of the sump. remove the internal oil pump and suction pipe. Block off the oil outlet from the pump.
I intend to run the pressure side after going thru external oil filter into the threaded portion where the oil filter used to spin onto.
The scavange side will go thru oil cooler and return to dry tank.
The other little present is an 8 stack Fuel injection system. Complete with a Holley Terminator ecu and coil near plug and accosiated wiring.
This was all supplied by a very good company in USA... Shakey B's Hot Rod Shop. They also supplied me with the fully finished bare block.
The pump still has to be fitted... the bracket it comes with assume its normal front engine with loads of front room !!!!
as we all know , space is very limited at front so going to have to modify bracketry to move pump back as far as possible.
Mounting it on the left side.
Have to squeeze in just one v belt pulley to drive the AIRCON pump ( this has 2 pulleys ) and then another v belt from AIRCON to alternator.
These will be mounted on the right hand side.. still got to design this lot and then fabricate.
A few pictures attached..
but
