SLC Door Actuators
I need to replace my door actuator and it looks like Hatchmasters is no longer in business ? Has anyone tried Autoloc or Dakota digital linear actuators?
Dominic
I have been noticing the same issue with Hatchmaster. I've left several messages and zero response. I'm searching for replacements for the recommended model 39A. I'm looking to confirm the spec on the Hatchmaster so I can match the lift capacity and stroke length. I have the 39A
cut sheet enclosed. The mounting brackets will need to be custom regardless. My plan is to use the InfinityBox motor controller module to control the unit. Make sure that the your selected controller can work with the actuator you choose. I'm still in shopping mode but wanted to offer my thoughts
  • Hatchmaster 39A Linear Actuator.pdf
