A few questions with my build…
1. I am installing the Kurt Urban steam/vapor recovery system on my LS3. The two plugs at the front of the engine are open but the two at the rear are plugged. What is the best way to remove those plugs?
2. I am aware that I need to have my Bosch high pressure pump mounted below the surge tank (my surge tank is elevated 2"). Can the pump be mounted side ways or does it have to be vertical?
3. Is it recommended to use a Swaglock fitting from the regulator to the fuel rail?
