any_key said:I know you'll need a matched cam, and distributer, but didn't even think about balance shafts
sfm6s said:I seem to remember there was a TVR Griffith racing in UK Historics with a flat plane crank some ten or fifteen years ago. The car made the Shepherd bros Cobras look slow which is saying something. The car didnt appear very often as it wasn't very popular with other competitors and was probably bending the rules a bit too much.
Sandy said:Still trying to get my head around the big reason for the v8 flat crank, is it predominitly for the lighter reciprociating weight and thus faster acceleration (Like tossing out the 30lb flywheel and runing a 15lb)?
Sounds like a very interesting package. Racing, might be interesting, but it had better twist well past 8k rpm to be compelling, as the longer 3.25" stroke motors are running well into that with good reliablility. I still like the regular 289 stroke Crank in the 4.125 Bore Dart block as the next motor as my interesting but simple combo.
It would be very interesting to find the weight of a equiv flat plane crank vs a nice lightned billet of equiv stroke (crower might have the info), and if you went to really light weight components (i.e. Ti Rods, pins) how much can you reduce the counter weights, and thus rotating mass on a regular crank?
Very interesting stuff again!
Sandy
salmjo1 said:Whoohoo, through an aluminum block in there, just for funIf I am reading correctly, you get to dump the counter weights all together, as the crank itself is balanced. Adding Ti rods... you really will be spending the kid's college fund, and then some.
