SVO motors come with stamped steel rockers that are secured with a bolt running thru a fulkcrum then thru the rocker and into the threaded boss on the head. There is no locking nut and if the bolt isn't firmly torqued down it will quickly become loose releasing the rocker arm.
I called Ford motor sport and got something about 1/2 turn after the valve to be adjusted is at 0 lash clearance (at TDC). That does not work and is in fact the correct way to adjust lifter preload on adjustable rocker/ hyd tappets.
It appears to me that if the valve is still making noise after the rocker holding bolt, on my type of heads, is torqued down the only way to "reduce lash", increase lifter preload, would be to remove any shims that might be there between the rocker base and the threaded pedestal in the head.
The Question, How do you adjust lifter preload on a 302 SVO motor with alum GT40X heads that have the oem lifters, pushrods, and stamped steel rockers?
If you know that one then how do you measure lifter preload?
